touringsedan
Hi,
I have a 1994 Olds Ninety Eight. The check engine light is coming on and off intermittently. It is running fine, but I have noticed a slight drop in fuel economy. I'm thinking it might simply need an O2 sensor, but I want to be sure before I purchase one. It has 117K on it, so it likely needs replacing anyway.
I have an OBDII scanner that will not pull the codes. I get an error message. I took it to Auto Zone and they got the same message with their scanner.
After some research online, I see some 1994's-1995's have the OBDII connector but are indeed running the old OBDI system, and that OBD was not manditory until 1996. So I have a feeling that is what I have here, an OBDI system with an OBDII connector.
I have a scan key device to read the codes on my 1992 Olds 88, which is easier than climbing under the dash to jump the a-b terminals. This device has a different plug for the old OBDI system, so it of course will not work on my Ninety Eight.
How do I pull the codes on this car? Is there a way to jump terminals like on my older car? I certainly don't want to fry the ECM messing around!
Thanks in advance,
Michael
Thanks in advance,
Michael
