I have had my speedometer act up since I got it. If you drive for 15 minutes or so it will start to work. It just start by jumping up part way if the correct speed and soon works perfectly. But if you use the signal light it will flicker up with the signal light and back down and up with the signal light. It is
weird. Also if you let off the gas it will sometimes show you the correct speed and when you touch the gas pedal to speed up it will drop . Any ideas
