Torque specs for CV Axle Nut and Wheel Hub (front end)
SE Michigan, USA
Good morning. Before I purchase new wheel hubs and CV Axle Nuts for my 2001 Oldsmobile Intrigue, what are the correct torque specs for both?
I know I need a bearing pulling tool as well to separate the hub from the knuckle (will purchase that as well).
This is what I put on my Excel spreadsheet (yes, I made one for reference):
Hub bolts: 96 ft. lbs.
Wheel Hub Axle Nut: 118-159 ft. lbs. <-- might be wrong on this and I believe it's only 150 ft. lbs.
Lug Nuts: 100 ft. lbs. (all GM cars used the same torque specs for the lug nuts for a long time).
Do I also need to add anti-seize or medium strength thread locker to the CV half axle assembly before putting the Axle nut on as well? I want to make sure I do this right and the front brakes will be getting new pads and rotors as well for better stopping (ceramic pads and rust-free rotors).
In the meantime, I'll be replacing the O2 sensor again (post-catalytic converter, aka, the Downstream (Bank 1 Sensor 2) as I have a pending code on that (cheap POS Bosch) and fix the exhaust noise from underneath with a flange and clamps or joints to interconnect the resonator and catalytic converter.
From the '00 Intrigue Service Manual:
Front Wheel Drive Axle Nut (New) 118 lb ft
Rear Wheel Hub to Knuckle Bolts 55 lb ft
Where are the torque specs for the front end suspension tie rod in nuts on a 2001 Oldsmobile Intrigue
