MAF sensor 90 delta 88 royale. Code 34.
OldBetty
Long beach
I'm getting code 34 from obd. I bought a MAF snesor a lil over a year ago. Do then really go out that much? I've taken it off cleaned it. But still get code. Saw that the air cleaner was dirty, could that play any part? I can reset the code and drive for a bit then it willmstill come on.
I don't want to have to buy another MAF sensor.
Hesitates when I accelerate. Stalls, bad idle,
Thanks community
I did go out an buy a Remanufactured MAF sensor and installed it. Noticed I could use a IAT sensor and air filter as well. I believe I reset the codes as well.
Its been about 5 days with new MAF and when I was cruising at a low speed and started to brake the car died! I was able to start it right back up and drive but when I performed the same action again car died.
Did a quick OBD test on the side on the side of the road. Code 34 comes up! WTF? So car starts right up and then while I'm driving "check engine" light goes away.
Could it be the "signal strength?"
Could I maybe use a new wire harness connector?
Thanks community!
