[ACCOUNT CLOSED]
Active member
- Joined
- May 9, 2005
- Messages
- 1,192
- Reaction score
- 4
- Points
- 38
Raising the Bar.....And Rebushing it
The only Eighty Eights or Ninety Eights from the '86 to '90 body style that came with rear bars were the FE-3 or F-41 suspended cars. A load leveler, different final drive ratio, 15" rims, NC6 "Sporty" exhaust, different rack and pinion, and a leather steering wheel were also part of the package.
I concur that you do not have to remove the strut from the knuckle in the rear, in fact, the idea is NOT to let the strut move on the knuckle or you will loose your alignment. But, you have to remove both of the strut to knuckle bolts at the same time to put the seay bar mounting bracket on the strut/knuckle assembly. I did not have to retain the setting because I was installing new struts at the same time and was getting an alignment anyway. One way to retain the struts position on the knuckle during removal of the bolts may be to squeeze the strut together with a C clamp while the bolts are removed, but I have not tried this. I used this gauge to mark my alignment before I took the strut apart:
Check out this link, I expained it in detail:
http://www.lesabret.com/phpBB/viewtopic.php?t=3558&highlight=
The FE3 cars leather steering wheel and load leveler make the cars easier to identify in salvage yards or classifieds. The Ninety Eights with the Brougham option (4th and 5th digits in the VIN are CW, not CX) came standard with a load leveler, but if you see an Eighty Eight with one it is an FE-3 car.
Far Out jfmc! Thanks for the FE-2/year/fitment info, and the picture :thumbsup:
I need to get one of those front and rear bars. How did you identify your front bar? By the FE2 on the trunk sticker?
