ECU Memory
96OldsNinetyEight
I got this 1996 Oldsmobile Ninety Eight Series II V6 about three years ago from a driver who drove way more aggressively than I do. I just recently replaced the battery for the first time since I've had it. I did not have it unplugged long enough to reset the ECU so my question is this. In those three years has the car updated to my driving style or should I fully reset the computer so it picks up on my habits. I'm pretty sure it adjusts without resetting but not 100% sure.
Your replies are greatly appreciated. Thank you.
The OBD II systems dont reset by unhooking the battery. Im pretty sure they just run according to how they are driven, whats demanded of them.
When the dealership put the last new battery in they unplugged it overnight and said it was to reset the cars driving habits...
OK, maybe, I guess it doesnt work to clear codes thats a different matter.
I think you are mis led here. The computer runs the air/fuel ratio and timing of the engine according to the throttle position sensor, air and engine temps and thats about it. There is nothing for it to adjust too. Further if youve had it for 3 years and it did need to "adjust" it did that along time ago.
I've been told by numerous people including the tech guy at the dealership that an ECU needs to adapt to the driver. I've also read a lot about people resetting their ECU's after performance modifications in order to get the most out of the mod. I'll do some more research and report back if I find out anything different.
With modifications the ECM's (electronic contol module) need to be recalibrated to deliver the proper air/fuel (A/F) ratio to meet the modifications so the car doesnt run lean. ALSO modifications to camshafts like performance cams OR to the rocker arms such as higher ratio rockers require a ECM recalibrations for ignition timing advance curves as well... more so for performance cams than rocker arms.
Now with a stock engine such as yours it can be driven hard and/or easy and the computer (ECM) just delivers the proper fuel ratio and timing advance accordingly to the information it recieves back from the various engine sensors.
A quick and probably not so complete basic run down of various functions:
You have a throttle position sensor (TPS) that tells the computer how much fuel delivery you are asking for. It adjusts the A/F ratio (and timing) accordingly
Then there is the O2 sensors that tell the ECM what the A/F ratio is and it adjusts accordingly.
Then you have a... forget the proper term... air intake temp (I think AIT) sensor that tells the ECM air temp which determines air density and ECM adjusts accordingly.
Then you have a MAF (mass air flow) sensor that tells the computer how much air is being fed into the mix (in conjuction with the TPS) so it can adjust the fuel thats injected from the injectors to keep proper A/F ratio.
Then there is a knock sensor that tells the ECM if the timing is too advanced causing preignition of the A/F ratio and adjusts the ignition timing accordingly.
You have a crank position sensor that controls the overall ignition timing
You have a cam sensor that controls the overall fuel injection timing
All these ratios and timings are precalibrated into the ECM for the proper stock performance of the engine and it just does the rest according to what the sensors tell the ECM is going on.
Alot of what you are being told is "folklore" that more applied to much earlier more primitive systems, such as less refined throttle body injection systems... and primarily had an effect on engine start up and cold idle.
If you car is running good with no check engine lights... its a happy camper, always delivering the proper A/F ratio and ignition and injection timing. If it throws a check engine light have a tech diagnose the problem and replace the proper sensors or parts if need be and it will continue to be a happy camper. ;)
Thanks Royale for the information!
And I doubt I should reset the ECU for this, but if I were to put a drop-in K&N element in would I?
