Lilmuddy
Imagine that . .an alero that cranks and wont start lmao (not)! let me give you details on what the car has been doing and then I'll finish with what I have fixed and what I know for fact. The car is a 2001 Alero with the 2.4L and an auto transmission. Mileage is ruffly 118,000.
March 10th: Did a tune up on the car. Replaced air filter, engine oil and filter, and spark plugs. I drove the car from Ohio to Mississippi with no issues. Car ran fine and got 30 mpg on the highway.
April 10thish: Got water on the pass. floor boards (front and rear) and a slightly damp drivers floor boards (front). There was a HUGE rain storm and I believe the water came in through a small hole I drilled at the base of the heater motor. The plastic was holding snow melt, which in turn would freeze the heater motor and then burn out the heater resister pack. Did that over the winter and have had zero issues since. I also have read about the rain ducts not being able to keep up in down pours causing flooding. Dried the floor and all ran and seemed fine. Made the return trip to Ohio and started to notice it was taking a little longer to crank and then start. Was very intermitant . .sometimes it would start right up and others there was hesitation.
April 25thish: Keep driving car, no other issues except for hard to start occasionally. Cranks just fine. Back pass. seat floor board is wet again. WTF?I pull the front seat fully forward and find a large puddle under it caught in between the "humps" Wet vac everything dry and all seems ok. I musta missed that part the first time.
May 1stish: Driving to work, its raining again and I hit a large puddle of water/pot hole while going around a right curve. Car DIES on the move and I quickly throw it in Nuetrel, restart it and carry on with no other signs of trouble or lightes illuminated. A day or two later car is getting harder and harder to start. Long cranks over 30 seconds, sometimes it would start still right away and others nope. takes two or three times to get it to start. Cranks normally and NO dash lights are illuminated.
May 5th: LOOONG cranking required to start after work, finally started but this time the "security" light stayed on. Ran fine, drove it home and had no other signs of problems.
May 9-11: Car starts acting up more and more. Security light is off and has NEVER come back on since. Usually long cranking required to get it started. Once or twice it started up normal, first touch of the key.
May 12th: DEAD, car turns over in its driveway grave but refuses to start.
Over the weekend here is what I have done and I have learned so far:
-New fuel pump and fuel filter. I didnt hear the old one turning so I figured it was bad.
-checked the fuel pump fuse and it has continuity and it has battery voltage to one terminal when key is in the run postion. All good there.
-New fuel pump relay, however still no luck.
- A small shot of ether (starting fluid) will get the car to try to start but it doesnt run. So, I have spark just fine.
I pulled out the haynes manual and studied/high lighted the power circuits relating to fuel. I have learned that the relay controls power to both the fuel pump and to the injectors. I have ZERO voltage to the injectors (gray wire). I will raise the car up tonight and check the harness connector going to the pump (vehicle side obviosly for power). I will also check for continuity to ground both from the relay terminal and from the fuel pump harness. BOTH of these (relay and pump) ground out to a ground splice pack. Ironically the "ground splice pack" also is a source of ground for the ignition control. There seems to be NO power from the PCM to energize the fuel relay but I need a better "pin" to probe the relay slots.
What controls the PCM and tells it to send power to the the fuel pump relay? Where the heck is the ground splice pack located so I can check to see if maybe its just a bad ground? I have searched and searched but nothing solid has been found. I did find that some GM cars have a ground pack located under the carpet (hmm . . mine got wet so did the ground rust and go bad?)
Things I will verify tonight is voltage to the relay or not from the PCM. I will also jump the relay slots to send voltage to the pump and injectors to see if I can get it to run that way. I know this is a long writing but I wanted to give all the info I can so it elimantes did you try this or what about that. From what I gather the alero has known starting issues, from the theft lock, to bad PCM's and also bad ignition key assmblies. Thanks for any and all help.
