Hey, first off thanks for checking this out!
Daughters car, not at home, 400 plus miles away... heading there tomorrow am to attempt to repair...she called Monday, said car started like normal, then as she put it in gear, died. It has not started up since. Fuel gauge is nonfunctional but I make her put some 5 to 7 gallons of gas in it just to be sure... she says she can hear the pump working.. I could not over the phone... sounded like it wanted to start... she has an obd code reader, and it is throwing codes, but not specific to not starting..(p0110, p0742, p0410, p0171.... I know what those are... but I did not think they would cause a no start, am I incorrect?) I was hoping it would throw a crank or cam sensor code... both of which I swear I have replaced.. but less sure on the camshaft sensor... Sooo... ordered one of those for her to pick up locally and hope to talk her through putting it in.... if that is, saves me a day of work and a trip out and back... if not... here is what I was thinking.. please chime in if you think I should do something different, or additionally:
1. confirm fuel pump is working
2. ck fuel pressure, if good, ck/replace fuel pressure regulator?
3. ck for spark... not sure how to do this, but maybe someone has a
suggestion.. was thinking pull a coil pack, use some old plug wires and see if
there is spark?
4.Crank shaft sensor... although I know I did replace that one..... but she did
have a starter issue, it basically broke into pieces... and possibly
wires/sensor damaged? Will a bad crankshaft sensor cause a no start
situation?
5. PASSLOCK? She said the security light was on, so we tried the relearn wait
30 mins and try to start.... no workie...
6.????
I have the set of factor service manuals.. and have not spent hours in them, but will bring them... been mostly looking here.... hard to fix on the phone... etc... any help/suggestions greatly appreciated...
there is spark?
situation?
6.????
