I'm working on a 1999 Olds Intrigue with a 3.8. I went to start it and it wouldn't turn over. Just a loud thud each time the key is turned. My initial thought was the starter which had a broken nose cone so it got replaced only to have it stop with a thud each time the key is turned.
I was able to turn the motor over by hand only going in one direction and that being back towards the firewall. I made several turns of the crank (not sure if I made a full revolution or not) and then tried to start it again. This time it wanted to turn like it was starting but then stopped again. I tried to rotate the crank forwards from the point it stopped towards the front of the car but it won't.
My question is, am I dealing with a possible broken timing chain or gears ?? I've been trying to find info on this but nobody else seems to be having issues like this with their 3.8....just my luck !!!
Also I'm assuming that the timing chain is towards the passenger side of the motor under the top engine cover....Is this correct !!! Does this engine have interference heads ?? Could I have damaged a valve because of this ??
