• 🔍 Like our community? You can tell Google to show you results from this site more often. Just Click Here and then click the empty checkbox on the right side of our name.
1992 Olds Delta 88 3800 v6
As an Amazon Associate we earn from qualifying purchases.
chris pennington
Age
46
The engine stalls when the temp reads 200 and will not restart till the engine cools down. Checked fuel system ok, plugs ok top of engine whines loud before it dies.
The engine purs like a kitten for 30 min. until the temp reads 200.
Please help if you have had this problem.
Iam lost.
welcome to OF
have you pulled any codes yet ,sorry i'm not up to par on this car ,but someone here ,should help you very soon
does the radiator fan come on at all?,i have seen in the past that for some unknown reason that plug will come undone ,on some car's
and maybe replace the thermostat
******use caution when messing around that fan **********************
pete
The top of the engine isn't usually going to whine... There is a balance shaft parked under the intake, but its very rare that I have ever heard of one failing...
You may want to check the Alternator and see if the bearings are trying to sieze up... Alternators ( CS Series ) are very likely to either just quit charging, or have a bearing failure...
If the car is running at 200F which is normal, I wouldn't expect it to just quit... There are usually other issues at play when that happens...
You will need to pull the codes and tell us if you have any and what they may be... I'm thinking if you do have any they may be a code 17 or 18... Good Luck
