Where is the CAMSHAFT sensor located?
gommee
Can any one describe it's location or have a diagram? 99 Intrigue 3.8 litre engine
I get a stutter upon acceleration and have replaced most of the throttle body sensors. I get an engine missfire code. Nothing specific. I have replaced the ignition switch for other reasons. I have read other posts that say try the Crankshaft sensor, but their SES light comes back on and it does not fix the issue. The camshaft sensor is the easier of the two to replace.
I have a 2000 Intrigue and the cam shaft sensor is above the starter. You need to remove the starter to have easy access to it. Was a pretty easy job to change.
The Crank Shaft sensor is above the starter on the front side of engine. The Cam Shaft Sensor is what I am looking for.
PLEASE HELP.
camshaft position sensor location ?
On the 3.8 L , the camshaft position sensor (CMP) is mounted on the engine timing chain front cover . I have a Chilton's manual and can give more info on installation , if needed ! Just let me know . :thumbsup:
on a 2001 3.5 interque the camshaft sensor is behind the antifreeze reservoir on the passenger side of the car remove the reservoir and you will see it about 6 inches down its about a 10 minute job
crankshaft sensor is above the starter
