where is Fuel vapor canister located
seen_bawl
Hi
oldsmobile 2001 intrigue
where is the Fuel vapor storage canister located
it has another name Canister purge solenoid
can someone add a photo for this part if possible
thank on advance
C&C
Mount Pleasant, SC
The EVAP Canister is located behind the drivers side rear wheel. The vehicle will need the rear wheel removed and the fascia splash shield removed.EVAP 001_LI.jpg
seen_bawl
Thank you, I've change to many parts at this car, but still get some pending at the code reader
One final problem EV pending no error code, I hope I'll be lucky to discover where is the problem
C&C you been a big help bro thank you
C&C
Mount Pleasant, SC
I don't want you to just chase parts but there is also the EVAP Canister Purge Valve; this one is located under the fuel injector sight shield ( top, engine cover).
