what I've done to my 1988 Oldsmobile Toronado thus far
shepard.te
56
Johnson City, TN
Date 10/18/2022
Odometer 78,077 mi
Services Performed at Chaparral Buick GMC Service Department
A/C accumulator replaced
A/C compressor replaced
A/C condenser replaced
A/C cycling/pressure switch replaced
A/C expansion/orifice valve replaced
A/C freon conversion completed to R134A
A/C receiver/dryer replaced
Air filter replaced
Alternator replaced
Brakes checked
Camshaft position sensor replaced
Catalytic converter replaced
Coolant bypass pipe/hose replaced
Cooling system checked
Drive belt(s) replaced
Emissions inspection performed
Four wheel alignment performed
Front brake pads replaced
Front brake rotor(s) replaced
Front strut(s) replaced
Front wheel bearing(s)/hub(s) replaced
Front wiper blades/refills replaced
Fuel pressure regulator replaced
Fuel pump replaced
Glove box latch replaced
Heater hose(s) replaced
Idle control valve/motor replaced
Ignition coil(s) replaced
Ignition control module replaced
Muffler replaced
Oil and filter changed
Radiator cap replaced
Radiator replaced
Rear brake pads replaced
Rear brake rotor(s) replaced
Rear wheel bearing(s)/hub seal(s) replaced
Rear wheel bearing(s)/hub(s) replaced
Safety inspection performed
Spark plug(s) replaced
Starter replaced
Tires rotated
Transmission filter replaced
Transmission fluid changed
Valve cover gasket(s) replaced
Date 07/07/2022
Odometer 77,885 mi
Services Performed at Discount Tire
Four tires balanced
Four tires mounted
Four tires replaced
Date 10/18/2022
Odometer 78,077 mi
Services Performed by me
LED Conversion of Interior Courtesy lights/bulbs
LED Conversion of Headlights (High/Low)
Headliner replaced
Hood/prop rod supports both replaced
Samsonevickis
When are you gonna get around to doing some work on the old girl??!
Haha, very impressive list, did you do any upgrades when doing the front struts or brakes?
shepard.te
56
Johnson City, TN
The front struts I converted using WESTAR Front Conversion Kit For Eldorado/Seville/DeVille/Reatta/Toronado/Riviera
