I did a search but could not find my exact issue. The car is a 2000 intrigue and I have had this intermittent electrical issue for about a year. When the factory radio was still installed every time I hit a good sized bump it would shut off and then turn back on. So I decided to install an aftermarket radio but still got the same problems. I then did a wiggle test and hitting test and found the wiring harness under the glove box was the issue. I then just ran the power and ground wires to other sources and that solves the issue with the radio so I left the problem unsolved as thats al that was affected at the time. Just last week I went to go start up the car again after driving around for a bit and the car would not start. Relays just clicked and would not crank. My thought was the ignition switch recall but that is not the issue. I thought maybe that wiring harness from before was causing the problem and when I wiggled the wiring harness right under the glove box, the car started right back up. I havent got around to do any deep inspection on it yet but was just wondering if anyone has experienced this issue before. Thanks for the help!
