oldsmobile intrigue 2000 3.5 DoCH v6
JadeNPunchy
I am pretty purplexed. I am not a mechanic by any strech of the means. I do however know I cannot be the only one.
The car that I have been working on its parts are all on recall. oldsmobile intrigue 2000 3.5 v6.
I need a Water Pump pulley. I had to weld this main wheel back on. I have had to replace the serpentine belt to find out there is only one belt. While learning my serpentine belt configuration. . I realize the Water Pump Lost pulley due to not tightning the bolts on the water pump pulley. This was done as a step to change the power steering pump.
This car has started to pick up speed on its own before the weld.
I am pretty sure paying 150.00 for a part that is so small. This should be criminal. I am self employed an my job is critical in these times.
My car has a job 2 do 2 šŸ˜‚
I am also very proud of learning the little I have but please someone paste some real links of a decent forum for parts.
My system is a reverse flow.it snapped a belt.it lost a pulley water pump pulley.
To those of you that work on cars. You are a god send on these.
