TimmyATC
I recently tried draining my cooling system as much as possible. I read in my the Oldsmobile Service Manual that to drain the most fluid you should drain the radiator, turn the bleed valve on the thermostat and also drain each of the knock sensors to get at the fluid still in the cylinders. I was able to remove the knock sensor from the farthest front of the car (the left side of the engine) but have had no luck in trying to reach the sensor nearest the firewall (the right side). I can see the sensor, but cannot fit any of my sockets or tools in the tight area. I managed to weasel one of my smallest sockets in the area, but cannot get it to grip the sensor. I was just wondering if anyone else has had this issue or at least tried getting at the knock sensor? Also, does it make that much of a difference to totally drain the system by doing the knock sensors? Thank you! I have a 1999 Oldsmobile Intrigue 3.8L.
