intrigue instrument cluster not working
Gvot57
I have a 2000 intrigue and when I first bought it the battery was dead. I jumped it and everything worked fine when I drove it. I changed the battery the the temp, speedometer, tach, fuel and the indicator lights for the trans stopped working. If I disconnect the battery for a while they will all work again and go out. Could that be a cluster or an ignition switch? Also I’m only getting 3-4 volts on the wire that feeds the cluster. I’ve also changed the ignition switch out with a junkyard one but it didn’t solve the problem so I swapped it back. Thanks.
Dawson
Do you have a OBDII reader to check for any codes? Usually service engine, anti-lock, and airbag indicate a broken ABS sensor wire if I recall correctly
