2000 intrigue automatic climate control panel goes dead at times and comes back on .is there a way to reset or pull codes from unit?trouble started recently.all functions work fine when display is on ,nothing works when display is off.Any ideas??
[snapback]7810[/snapback]
Originally posted by acrazyangel@Jul 14 2005, 02:06 AM
The problem could be a that the main computer is not talking to the A/C unit. That is one of the many problems my Olds is having right now. Since my basic scan showed that there was a problem/defect with the PCM (main computer in car), I called Oldsmobile today and they informed me that the PCM has a warranty on it from GM that is 8ys/80,000 mile. If you would like more information you can call Oldsmobile @ 1-800-442-6537. Have you Vin number with you when you call, they will help you . I hope this helps.
[snapback]9915[/snapback]
I'll have to look at my ignition switch too, my HVAC won't start up sometimes and the Curise control does not work at the same time. I can pull my key out of the ignition switch while the car is running, it's pretty loose.
