Hi 1984 Oldsmobile Delta 88 Bad Radiator need some Help
whats up yo
Hi I need some in-put from someone who has been there ,What do you do when the Transmission cooler lines are rusted to the radiator Brass bolts and stainless line yep rusted carries cool water to transmission . The radiator leaks won't hold water when it gets hot so I have a rebuilt one and can't get the bolts loose if you turn them it will crimp the trans lines ,the brass bolts are supposed to spin free on the stainless lines tried Penetrating blaster Bolt oil . I have been told to cut them and splice on a rubber high pressure fuel line with screw down tighteners on each end. I hope someone can help who knows the facts changed one or two in their travels.. Thanks for help
GMT 1300 hours 34 views no help
Thanks for the views an no help ,Also the popups on this forum are the most annoying I have seen on the internet as of late . This is a great example of a neglected website Thanks BTW I fixed the problem
the fuel line will work ,I have used compression couplings they work also
