1942wildbill
- Joined
- Nov 16, 2012
- Messages
- 1
- Reaction score
- 0
- Points
- 0
- Age
- 83
'95 Olds Cutlass Ciera, 6 cyl., rear drum brakes. These brakes were replaced several years ago by an Olds mechanic. Shortly after, the rear brakes began grinding when applied. A check of the shoes revealed that the brakes are rubbing against the side of the drum. Bought new shoes from Autozone, exactly the same width of the previous set installed by Oldsmobile. Still grind on application. Ground 1/16" off the outside of each shoe, hoping that would clear the drum. Still grind. Any ideas about resolving this problem short of replacing the drum? That's my idea of last resort -- Bill
