U
Unregistered
So it will stall whether the car is warmed or cool. The dealer said the code he got said it was the crank sensor. He says labor will take about 3 hours to replace it and 290 dollars from my wallet. Fair deal or no?
Heres a description of what the car does in case you have any diff thoughts on it.
The problem I have had for some time now is the car cutting out on me as I drive. No sputtering stall just turns right off. I then pull over to the side of the road and either turn the car right back on, or can't start it again from anywhere 5 mins to an hour at the most so far. One exception to the stall was that I was accelerating from a stop light when the car cut out, then kicked back in a second later which caused the car to lunch forward. It then didn't stall till the next time I drove. Of course then again it could go weeks without happening.
