I have a 1993 Oldsmobile 98 supercharged Touring Sedan with automatic climate control with dual passenger controls. I have had an intermittent blinking of the temperature numeral display about one minute after start up that flashes about 20 some times and then acts normal. All functions work after that except for lately. Despite the outside temperature being 40 degrees outside, the display shows it blowing out the bottom vents, but what is actually happening is hot air is blowing out the drivers side floor vent like it is supposed to, nothing coming out of the passenger side floor, but a cold artic blast of air coming out of just the right(passenger) side defrost. I set the automatic temp control to 75 degrees because I like to be warm and let it do its thing.
The craziest thing about all this is that sometimes after about 2 to as long as 9 weeks later it will sometimes heal itself and does just fine. What always seems to trigger it is when the battery cables are disconnected or the battery goes down. I recently had a rebuilt transmission put in it. When it came back: Guess what? Flashing display again. I found an unhooked vacuum line under the hood. Hooked it back up and it went away.
Currently the display is flashing again. The alternator locked up and had to be replaced two weeks ago. Disconnected the battery and it started flashing again. Looked under the hood for more vacuum leaks. Replaced the check valve coming off the engine that goes to the vacuum resovoir tank and the cruise. Problem went away.
I left the map light on Monday Feb 23rd. Came out Tuesday. Battery dead. Charged up battery that day. Started car up. Guess what started flashing again. Still blowing out the wrong vents as described up above. Opened hood. Bypassed new check valve and resovoir tank and hooked vacuum directly to cruise and heater controller by way of a t fitting. Disconnected battery to supposedly reset the code. Still blinks and works wrong.
I have a service manual. It says to simultaneously press the warm and off buttons and the entire HVAC display panel will light up all its digits and indicators. It does not really have a "Warm" button, so I am assuming that they mean to press the warmer side of the rocker switch that adjusts tempurature. I have seen this mode work before when I pressed the buttons and the display lit up, but it has been a long time. Currently, this function does not work.
This is where I am at. The floor is now open to suggestions and questions.
Thank you for your patience and time spent in reading this. I love Touring Sedans, but this one is out to drive me crazy.
