2002 Bravada running lights not working
pjjjr
Tail lights not working, Here is the store; after hooking up trailer lights everything worked except running lights. To make a long story shorter, I replaced everything on car and trailer from the wiring harness back. Still nothing. So, I took tail light assembly apart, hooked a wire to the brown tail light wire then ran it down to the wiring harness. Everything work on trailer, but only for about 2 days. I lost taillights on trailer, and also lost left side running light. I then unhooked trailer to focus on tail light. I made sure bulb wasn't blown. To get tail light to work, I took a wire from right brown tail light wire to the left. Everything worked but only for about 10 minute.
I checked light bar assembly and that is good, bulbs are good, all fuses are good. Is there a hidden fuse box or any connection anywhere else in this 2002 Bravada?? Any help??
