I have a 2000 Oldsmobile Intrigue GLS that has been overheating the majority of the times I'm idle in drive/neutral. Now, I'm not going to lie, I've been putting the wrong coolant in it. Instead of DexCool 50/50, I was putting the full DexCool and mixing it with water.
Just last week, I decided to switch back to DexCool 50/50 (it was my dad's idea for the strong stuff since you would get more)
Since then, I've noticed the check engine light has gone off, the coolant appears to be staying in the tank, and it doesn't overheat when I'm idle. I didn't mention this, but with the other stuff I've been using, I would need to refill my coolant every other day.
Just tonight however, after coming off the highway at a redlight the thermostat started acting up on me again. It did and has gone done when I rev'd up the motor between 3,000/4,000 RPMs. I'm not sure what it is at this point. If I'm idle when I don't go on the highway, it's fine, but when I go on the highway and I have to stop for a long period of time, it acts up.
I've read about the radiator fan. Now I'm not sure exactly what that is, is that the fan that comes on when the car starts over-heating? If it is, I haven't been hearing it turn on recently when it's been acting up, but then again, I might not hear it because of the music.
Would you guys know why it's been acting up ? It seems to be running alot better now that it's back to the 50/50 coolant. I thought there was a leak because with the other stuff I would need to add more coolant every other day, but since I went to the other stuff, it appears to be staying now. I filled it up yesterday and did quite a bit of driving. Normally, I would need to refill it today, but it was where I filled it to yesterday.
I've had the thermostat replaced twice already.. So I'm not sure if that's the problem. What about that fan? Ever since the 50/50 has been running in the system, it's been running great just until tonight after I got off the highway..
