2.4 I4 alero problem
99 Alero I4
when you shift out of first gear any one else feel thier car shudder... it happsn mostl whne im nailing the gas for somthing but somtimes even when im driving normally...
and where is the button that resets my change oil light can't find the tircky bastard
Change Oil Light
I can't exactly help you with the 4-cyl shifting problem, however, I can help you with the Change Oil Light. I'm sure someone will be along soon to assist you with the other issue.
This has been addressed in the following thread:
http://www.oldsmobileforums.com/forums/showthread.php?t=2173
as well as in your owner's manual.
The switch you are looking for is small and red and located in the Driver's Side Dash Fuse box (between the door and the instrument cluster).
Good Luck!
joc1394
2000 Olds Alero GL2
3400SFI V6
<edit>
I just noticed...you can find the exact steps under "How To:" which is stickied to the top of the forum!
http://www.oldsmobileforums.com/forums/showthread.php?t=2301
Good Luck!
<end/edit>
