Go Back   Oldsmobile Forums > Older Requested Oldsmobile Models > Oldsmobile Toronado
Oldsmobile Toronado Forum specifically intended for Oldsmobile Toronado based discussions.
Oldsmobile Forum: 66 Toronado Turn Signal Actuator
Old May 22nd, 2008
ProudtobeOlds ProudtobeOlds is offline
ProudtobeOlds is on a distinguished road
I am trying to locate a “Turn Signal Actuator” for a 1966 Oldsmobile Toronado with a Tilt and Travel Steering Column. This is not the switch it is the actuator in the column with the cable that runs done the column to the switch mounted on the column below.
Any info you can give me regarding will help. Thanks
Old October 3rd, 2008
Tx67toro Tx67toro is offline
Tx67toro is on a distinguished road
good luck, I am trying to find one for a '67 with tilt/tele and cornering lights. Was told this morning that those are pretty much extinct.
Old October 4th, 2008
ribspot ribspot is offline
ribspot
Hi Guys,
Pretty much salvage yard is your only hope. Then you have to hope what you find is any better than what you have. Those are 66/67 only not used in the later years.
You might try checking with the toronado owners association to see if anyone there has a source. TOA@toronado.net
good luck
John Kelsey
Dayton Ohio
TOA# 009
Old October 22nd, 2008
Am repairing mine. The turn signal lock on the cam itself was worn off, so am reconstructing it with liquid ABS plastic and shaping to match the good one. The salvage yard near me has 7 66/67 toros, but none of them have the steering columns in them.
Old December 7th, 2016
barrymb barrymb is offline
barrymb is on a distinguished road
1966 Olds Toronado Turn Signal Actuator
Hi all,
I know that I might be 8 years late, but I can actually make a turn signal actuator on a 3D printer that fits a 1966 and 67 Toronado with tilt wheel. If you are interested, you can contact me through the forum.
Barry
Old October 30th, 2017
dtollison dtollison is offline
dtollison is on a distinguished road
I am interested in one. Thanks.
  #7
Old June 12th, 2018
RussBarnes RussBarnes is offline
RussBarnes is on a distinguished road
Barry,
I sent you an email the other day about a turn signal actuator for my 67 with tilt/telescope and cornering lights. Did you receive it? I need your skills.
