Notices
Oldsmobile Forum: 1994 98 Recency issues
Old May 9th, 2017
Otay67 Otay67 is offline
Otay67 is on a distinguished road
I just purchased a olds 98 Regency (1994). It runs good most of the time but sometimes when cruising at steady speed the engine will seem to shudder once or twice,the engine light will come on and it seems to cough a bit like its hurting for fuel. There has been a few instances where it acts like it is starving for fuel,it just has a cough and won't go for a moment or two. Once it just shut off at a red light while it was idling just fine,it did fire right back up. Once it would turn over but wouldn't start for 15 or 20 minutes,then a half hour later it fired right up. Any help or thoughts would be appreciated.
Old May 10th, 2017
NINETY EIGHT REGENCY's Avatar
Administrator
ADMINISTRATOR
fuel filter, fuel pump, pcv valve, coil packs, spark plugs...
__________________
RANSOM ELI OLDS REINCARNATED
Old June 15th, 2017
beast360 beast360 is offline
beast360 is on a distinguished road
loose connections at fuel pump, no joke some loser put butt connectors on my on some carter pump when i dropped the tank few yrs back, alos check the TCC solenoid by the brake pedal as well
cars connected social network cars connected social networking app for ios cars connected social networking app for android
suspension parts, shocks, struts and more
Copyright ©2000 - 2018, vBulletin Solutions Inc.
