Oldsmobile Forum: 97 Olds Bravada Brake Issue
Old April 16th, 2017
bob223 bob223 is offline
bob223 is on a distinguished road
I have a problem that's just started with the brakes.
When you apply the brakes, it pops the master cylinder cover off. It's just 1 corner, not the whole cover. Hasn't leaked any fluid at all and it still stops, but not the way it should.
The pedal feels spongy, like it needs bled, and there's a sort of hissing sound when you push the pedal.
I'll put the cover right back on, it'll work normal for maybe 4 0r 5 stops, then it pops the cover off again.
Any ideas?
Thanks.
C&C C&C is offline
C&C is on a distinguished road
It sounds as you have a bad master cylinder; perhaps one of the circuits is malfunctioning and blowing back into the reservoir and instead of pressurizing the brake line it is creating pressure in the reservoir. If you can observe the brake reservoir (cover off) with someone else applying the brake, and you see bubbles or an out flow into the reservoir, that might confirm the error's origin. In any case, it appears to be a serious safety concern, and needs to be fixed.
bumpinJ bumpinJ is offline
bumpinJ is on a distinguished road
Definitely have you master cylinder checked, especially it doesn't hold the pressure consistently.
Old May 16th, 2017
Ended up being a blown diaphragm in the brake booster.
