Go Back   Oldsmobile Forums > Older Requested Oldsmobile Models > Oldsmobile Cutlass > Oldsmobile Cutlass FWD
Oldsmobile Cutlass FWD Forum specifically intended for Oldsmobile Cutlass front wheel drive based discussions.
Oldsmobile Forum: Oil pump drive tip
Old 3 Weeks Ago
Walter F Walter F is offline
Walter F is on a distinguished road
Oil pump drive tip
As owners of 3.1 equipped Cieras well know, the oil pump drive is notorious for leaking. This sits on the top of the engine block where the distributor used to go before coil pack ignition. After changing my lower intake manifold gaskets I had a small oil leak. After every gasket had been changed the leak persisted.
I finally identified the source as the hold down bolt for the oil pump drive. If you are installing a new O-ring in yours be sure to tap the drive unit down after you think it's seated and apply sealant to the hold down bolt.
