Go Back   Oldsmobile Forums > Older Requested Oldsmobile Models > Oldsmobile 442
Oldsmobile 442 Forum specifically intended for Oldsmobile 442 based discussions.
Oldsmobile Forum: Disc Brake Conversion 72 442
Old December 24th, 2015
jpru5112 jpru5112 is offline
jpru5112 is on a distinguished road
I've been thinking about installing a disc brake conversion kit on my '72 442. OPG has them.
https://www.opgi.com/cutlass/1972/br...rakes/G240378/
Just wondering if anyone here has done this and was it worth it?
Old December 25th, 2015
Rocketguy Rocketguy is offline
Rocketguy is an unknown quantity at this point
Hello jpru and welcome to the forum!
I believe these kits are made by The Right Stuff and I have installed them. The installation was straight forward and the difference it makes is incredible.
The two biggest surprises were that the bracket for the rear brake hose has to be welded to the axle and due to the thickness of the rear rotors longer wheel studs had to be installed.
Since most of the cars I work on have low vacuum cam shafts I will not install power brakes with this kit again; I'll use a manual disc master cylinder.
Old December 28th, 2015
Just ordered it today.. We'll see how it goes.
