Go Back   Oldsmobile Forums > Most Recent Oldsmobile Models > Oldsmobile Bravada
Oldsmobile Bravada Forum specifically intended for Oldsmobile Bravada based discussions.
Oldsmobile Forum: Default 1998 Bravada Smarttrak not working anymore
Old October 14th, 2018
Bossman Bossman is offline
Bossman is on a distinguished road
So I've been having this problem since last winter when it started not working. I finally put some attention to it by researching sites and changing some stuff.
So I changed the fluid to the blue type II stuff. What came out was red, but wasn't stinky and was full. I never had any grinding or locked into 4x4 mode problems.
I changed the encoder motor and put a refurbed TCCM in. I did a bit of testing on gravel today and it spun out and fish tailed. No hint the AWD was active. Also I have checked both fuses that I'm aware control the AWD. One in the cab fuse panel and one under the hood.
I have no light on the dash. It doesn't even come on when the key is turned to the on. I know the LED is NOT burned out because just last week before I did this work it was coming on now and then. Now that was weird, but when I went to change the computer out I found a bit of moisture. So some rain must have got down there and maybe was doing something, I don't know. I was messing around with the computer prior to this and didn't see any water.
If the speed sensors were bad, the dash light should come on, right? I'm at a loss on this. It ticks me off they have to keep making things more and more complicated. Any input on what to check would be cool.
Old October 17th, 2018
Just as I thought. The Bravada is giant POS and these forums are completely useless anymore.
