Go Back   Oldsmobile Forums > Older Requested Oldsmobile Models > Oldsmobile Eighty-Eight (88) > Oldsmobile 88 RWD
Oldsmobile 88 RWD Forum specifically intended for Oldsmobile Eighty-Eight (88) rear wheel drive based discussions.
Oldsmobile Forum: Engine hesitates during upon acceleration - Delta 88 w. 307
Old August 22nd, 2018
Stephen0523 Stephen0523 is offline
Stephen0523 is on a distinguished road
Hello all. I am experiencing slight hesitation and Starting off from stopped position or sometimes from acceleration. Would anyone have some ideas where I should start looking?
Old January 11th, 2019
moevus moevus is offline
moevus is on a distinguished road
Carb
Adjust carb, those are ecm controlled for idle only,,,need multimeter, recheck cap and rotor and timing too.
Hi moevus, thanks for the tip. An old mechanic I used to use while I lived in Hamilton Ontario Canada took the car for a drive and knew exactly what was the issue, he cleaned and took apart the carb. He also said he drilled some holes on the bottom (not sure what he did) but it now runs like it is new!
