Go Back   Oldsmobile Forums > Older Requested Oldsmobile Models > Oldsmobile Cutlass > Oldsmobile Cutlass RWD
Oldsmobile Cutlass RWD Forum specifically intended for Oldsmobile Cutlass rear wheel drive based discussions.
Oldsmobile Forum: 1972 Cutlass Supreme will not start
Old October 1st, 2016
enriqueg862 enriqueg862 is offline
enriqueg862 is on a distinguished road
Can anyone suggest any possible fix for a 1972 Cutlass Supreme that will not start. I turn the key and it will not crank. I use a screw driver on the starter and it starts. Any help is appreciated.
Old January 31st, 2017
olds1948 olds1948 is offline
olds1948 is on a distinguished road
72 cutlass not starting
you may have a few problems. you will need a 12v test light and a helper. then 1. check neutral switch (likely) 2. broken or burned soliniod wire 3. bad ignition switch. hope this helps olds1948
1970cs 1970cs is offline
1970cs is on a distinguished road
I would assume that you have an automatic? You could try to rotate the collar to full left on steering column. It's quite possible that the back drive linkage is worn.
Pat
