Go Back   Oldsmobile Forums > Older Requested Oldsmobile Models > Oldsmobile Eighty-Eight (88) > Oldsmobile 88 RWD
Oldsmobile 88 RWD Forum specifically intended for Oldsmobile Eighty-Eight (88) rear wheel drive based discussions.
Oldsmobile Forum: Antenna
Old September 14th, 2016
Stephen0523 Stephen0523 is offline
Stephen0523 is on a distinguished road
Antenna
Could someone tell me how I would know if my antenna is a power antenna or fixed antenna? I inherited the 84 Delta 88 Royal Brougham from my uncles and I'm wondering how to fix it or does it need to be fixed?
Old October 31st, 2016
D. Yaros D. Yaros is offline
D. Yaros is on a distinguished road
I cannot believe you have not had a response.
The simple way to tell if your antenna is powered is to look for an antenna switch on the dash. If there is not one to be seen, that is a clue it is a manual antenna.
Is the antenna mounted on a front fender or in the trunk? Can you see a large round housing on the bottom of the unit? That is where the nylon cable that drives the mast is located on power antennas.
Old November 1st, 2016
Rocketguy Rocketguy is offline
Rocketguy is an unknown quantity at this point
Good advice DYaros.
Stephen; show us a pic of your antenna and we can tell you
Old December 13th, 2016
amcnut amcnut is offline
amcnut is on a distinguished road
Power antennas on cars of this vintage were 100% automatic, they went up when the radio turned on and back down when the radio was turned off. There was no separate antenna switch, so that is not a good way to determine if it's power.
The power antenna will have a mast that has separate sections that telescope down into a well in the fender.
The non-power antenna on this car (if not embedded in the windshield--look for two wires running right up the center of the windshield) will be also fender mounted, but it's a solid stainless steel shaft that screws onto a base.
That's going to be your only reliable way to determine what you have.
Old January 8th, 2018
hurricane62417 hurricane62417 is offline
hurricane62417 is on a distinguished road
amcnut is 100% correct...if it doesn't have sections...its not powered
if it does...and doesn't move or you don't hear the motor making a sound for it
to go up and down when turning on/off the radio...it could be unplugged
from the motor or the motor is shot or a fuse is...
