Oldsmobile Forum: 92 Bravada 4.3
Old January 8th, 2005
mojiles mojiles is offline
mojiles
Thumbs up
My 92 Old's Bravada is becomeing my worst nightmare, it has a 4.3 W code engine. every 6 months ( or less ) it's back in the shop with an elec./emission problem. My last and most costly problem is the engine sputters and cutsout within the mid range of the throttle, it's fine at an idle and great when floored.
This has been ongoing for about 2 years, I have had it in the Old's shop, GM shop, and a local shop, I have had the ECM replaced twice and fuel injector replacement and the problem continues to return. whatever Temp. sensor that makes the gauge register on the dash quit working but the Local shop told me it's not part of the ECM loop ( indication only ) Help I need a new idea ?
( I would get rid of it, But I enjoy everything else about it )
Old January 9th, 2005
erw38's Avatar
erw38 erw38 is offline
erw38
[snapback]4434[/snapback]
Is it throwing any codes? Throttle position sensor?
mojiles
Originally posted by erw38+Jan 9 2005, 01:47 PM--><div class='quotetop'>QUOTE(erw38 @ Jan 9 2005, 01:47 PM)</div><div class='quotemain'><!--QuoteBegin-mojiles@Jan 8 2005, 03:18 PM
[snapback]4438[/snapback]
[/b][/quote]
mojiles
I was told any codes relayed were not related to the engine problem ?
jbritt67's Avatar
jbritt67 jbritt67 is offline
jbritt67
I seem to remember a problem with the fuel pump pressure regulator that affected the 4.3 engines in S-10 Blazers / GMC Jimmy / Olds Bravada in 1991 -92.
I can't find the exact TSB yet, but I did find a partial listing on the link below.
http://www.autosafety.org/article.php?did=132&scid=60
I'll dust off the cobwebs and try to remember what I heard and where.
Old June 1st, 2005
Mattl's Avatar
Mattl Mattl is offline
Mattl is an unknown quantity at this point
One thing I learned with my 98 is that if there is a problem, mechanical or otherwise it is always a good idea to check for error codes & clear them out as practically everything in some way affects or is affected by the computer. Around the five year mark before I replaced my battery I was getting fluctuations in voltage. After I put the new battery in, my truck was not running well. I managed to get it over to a local autozone and had them plug their code reader in. It had a couple error codes which they cleared out for me and it ran just fine. Just my 2 cents. I'm not a mechanic.
