Oldsmobile Forum: 2001 Intrigue Project
Old October 25th, 2011
Aiyania Aiyania is offline
Aiyania is on a distinguished road
Hey folks. New guy here looking to get some perspective from fellow mechanics or fellow intrigue owners. I will try to get pictures to go with this post I plan on keeping up to date. I also will try to reply or respond to users as much as possible.
Restore project on a 2001 Intrigue. 155k miles. 2.5/3 out of 5 atm.
List of issues to date:
fix rear brakes/rotors
fix driver rear wheel-bearing
Turn signal goes in and out.
Front wheel needs work, maybe strut or something worse.
New brake lines.
Current Project:
None
Finished Project Comments:
~both rear bake pads-N/a
~both rear rotors-N/a
~driver rear wheel-bearing hub assembly - the factory abs clip and the abs clip on my new one seam a bit different. The factory one, the clip stub on the hub was toward the back and they veered up, so the clip would pop on tight. But the new one, has the clip stub located in the middle of the plug, and wont allow the clips to go over it. So I just plugged it in and used some electrical tape. If anyone knows a fix to this, i am all ears. Also if anyone is going to attempt this. There are more parts that look the eye that need to come off. You need to remove the parking brake ring. There is also a plate with Star screws T-30 from back side, that hold the parking brake trigger with a spring that need to come off.
-I am NOT a mechanic. Any advice given though my trial and error should be taken with a grain of salt. I am not responsible to mishaps ><
Old October 27th, 2011
RealtorBenjamin RealtorBenjamin is offline
RealtorBenjamin is on a distinguished road
for the turn signal just replace the bulb SOCKET. i did it on both mine and its good to go.
the lights turn on when i hit the hazards but when i hit the turn signal, nothing. that rules out the bulb.
i went on amazon.com and ordered them (cheaper than anywhere else I could find, and free shipping if the total order was above 25.00).
i'll get you the part number if you want it!
Old October 29th, 2011
Problems i can list with my turn signal.
While on, will stop for no reason, and return as well on its own.
Just wont work.
The hazard button will sometimes not work.
Things that cause it to sometimes randomly turn on.
-tilt on steering wheel.
-hitting wheel
-turning on windshield whipers.
Any ideas?
sparcx sparcx is offline
sparcx is on a distinguished road
Just wont work.
-hitting wheel
Any ideas?
do a search on the intrigue and replacing the hazard switch. I forget the exact symptoms, but it sounds like yours might match up with that.
might find something in one of these:
http://www.google.com/search?hl=en&c...+hazard+switch
