Oldsmobile Forum: 02 intrigue abs,ses,trac light on
Old 3 Weeks Ago
mrhappypantz mrhappypantz is offline
mrhappypantz is on a distinguished road
Hi, first i will say i have replaced front left and righht wheel hub assemblys over past 2 yrs,then i had the 3 warning lights again abs,ses,trac off light up, replaced right front harness, light went away, 2 weeks later lights came back, i can clear codes but lights remain on sometimes, but no codes show, but check codes again after drivi,g code or codes are bsck. I checked ohms to sensor 1085 ir so,checked dc volts on harness with key on at the sensor connection 4.85, checked ac voltage at sensors and the volts go up when i turn each wheel,codes i get is c0040 and sometimes c0035,and sometimes with those codes c0245? Only thing that stands iut is when checking ohms on right front if i lift the connector and wire to sensor while checking ihms reading sometims goes from 1085 to OL, move wire again then back to 1085? I dont see any broke wire on sensor connector to hub as far as i can see, any ideas? Any other tests to know if its that sensr connector to hub that is issue? Realkt dint want to replace hub again if its not that, just reolaced it 6 months ago.
Old 3 Weeks Ago
Check the fuse under the hood (it's a 10A standard fuse, not maxi fuse or relays) to see if it's blown. I'd also do a light bulb test on the ABS wiring to see if it lights up or not. If it does, the wiring is good. If not, check the fuse as I stated. Use the ACDelco brand hub assemblies since the cheap Chinese POS quits after 1 second. My 2001 Intrigue has that issue and one of the magnets broke or disintegrated, which caused a gap 6 years later (was on and off, then back on, and staying on).
