Oldsmobile Forum: Rough Cold Start
  #11
Old February 1st, 2016
olds99er olds99er is offline
olds99er is on a distinguished road
I located the ECT behind and below the throttle body, and turns out the two wires (black and yellow) were chewed off by a rodent (I think). I could repair the wiring if I knew where the ECT wires connect to the rest of the car. Anyone have a wiring diagram??
  #12
Old February 2nd, 2016
https://www.google.com/#q=200+olds+intrigue+ect+wiring
  #13
Old February 5th, 2016
Good find!
Anyone know where the PCM is located? I'm going to assume the PCM for the 99 is the same as the 01.
Thanks!
  #14
Old February 6th, 2016
Good find!
Thanks!
Yup, the PCM is in the same place for all Intrigues. In fact, for "most" GM cars, it's in the same place - under the air filter in the engine bay.
https://www.google.com/search?q=2000...ation&tbm=isch
Btw, fwiw, many GM PCMs are interchangeable.
But, the PCM must be programmed for the year, model, and engine. Some may have additional program options.
Good Luck!
  #15
Old October 14th, 2017
steel steel is offline
steel is on a distinguished road
My car has had rough starts for years. Once it is warmed up it idles fine.
