Oldsmobile Forum: Speedometer going crazy
Old April 6th, 2019
lil9er lil9er is offline
lil9er is on a distinguished road
1998 intrigue. Chasing a no crank problem. Ave changed ignition switch and lock tumbler. When switch is turned to acc speedometer goes to 100mph and buzzing under dash I believe from daytime running lamp module. Fuel gauge not working also. Anyone have ideas. Also had replaced bcm, but not sure on quality of reman I received. Thanks
Old April 7th, 2019
First things first: check the battery voltage and make sure that it has a good amount of voltage, check the PCM fuse and other fuses if they are blown.
Old April 7th, 2019
Have gone through fuse box twice. Have a battery charger hooked up while trying to do the 30 minute reset.
