Oldsmobile Forum: Oil Pressure Reading
Old January 27th, 2019
stuhrling stuhrling is offline
stuhrling is on a distinguished road
Can Oil Pressure (PSI) be read through the OBD2 port on a 2002 Olds Intrigue?
Appreciate any help!
Old January 28th, 2019
I'm pretty sure the answer is no.
Although, that is interesting.
Many GM engines will shut off the engine if the oil pressure is too low (the PCM stops fuel and spark).
And, many GM engines will also not start (no fuel or spark), until the oil pressure builds to some low value.
Iirc, both of my Quad 4 engines (Achieva '92 SOHC, Achieva '94 DOHC) require a good oil pressure signal to start.
Fwiw, I have a Tech-II clone.
As far as I can remember, I don't remember ever seeing any oil pressure reading on my 2000 Intrigue with the 3.5L LX5 V6.
