Oldsmobile Forum: 2001 Intrigue overheating issues
Old September 25th, 2018
[SOLVED] 2001 Intrigue overheating issues
One issue after the other. Currently, my car is overheating for some odd reason, there was no heat until I replaced the thermostat (aftermarket from Autozone since they don't sell ACDelco parts) last night along with my dad, and there aren't any leaks either externally (hoses are clamped and connected, and no cracks, splits, or holes) or internally (head gaskets are still good). The radiator fans do run without issues as they were running to cool down the radiator.
I am going to be doing a coolant flush tonight, though. What else can cause the car to overheat? My guess is a blocked hose somewhere.
Edit: I didn't realized I crimped the cooling system hose when my friend and I replaced the spark plugs. All's well.
Edit 2: Overheating again.
Edit 3: My dad forgot to tighten the cap all the way on the car's reservoir, which shot straight up and boiled out. Fortunately, the cap was still there.
Old October 14th, 2018
Jo schmo Jo schmo is offline
Jo schmo is on a distinguished road
I have a 2001 intrigue as well and a couple years ago I did a radiator change and had the same issue, I found out that with these closed systems you have to bleed air out the engin itís not to difficult you must jack up the front of your car and open a bleeder screw on your radiator by your passenger side headlight, open your reservoir and fill to full , open and close your bleeder screw letting out air until you see only coolant at a steady flow. Fill back to full close everything up, drop car and let engine get to running temp. I would start this process with the car just a little warm but not cold.
Old January 23rd, 2019
I belched the cooling system this past Saturday by putting coolant in the tank, started the car, waited a while, and topped the coolant off until the jug was empty. I also re-adjusted the hose from the coolant tank to the thermostat housing as I realized my calculations were a wee bit off, same thing with the clamp. As a precautionary measure, I have a full gallon of Dex-Cool 50/50 Antifreeze/Coolant in case I need to add more.
Old February 4th, 2019
Well, I found the problem. It was leaking out coolant from the return port on the top right of the coolant recovery tank. Why that happened was because I was attempting to take the hose off of the tank when I was doing the power steering on my car and pulled it too hard, and luckily, the hose wasn't damaged. I bought a new one at O'reilly Auto Parts store (formally Murray's Auto Parts) on Saturday and installed it on Sunday. I carefully inspected the hoses and clamps before installing the new tank and I checked the cap, and the coolant level sensor on the old tank and they looked pretty good still. No more steam coming from the tank, no coolant on the belt, and no squeaking from the pulleys. The coolant is still full and I'm glad I finally got the cooling system fixed on my car.
Old February 5th, 2019
C&C C&C is online now
Glad you found the problem and coming back to update the resolution.
