Oldsmobile Forum: 2001 intrigue
Old August 24th, 2018
greg101 greg101 is offline
greg101 is on a distinguished road
2001 intrigue
2001 3.5 engine, trans swap into 1998 intrigue 3.8 will i have wiring issues i do have complete harness and computer from the 2001
Fwiw, anybody that asks if they can swap engines in a computer controlled car, should not even think if it!!!!
Get a 3.8 from the junkyard.
Imho, it's a ZILLION times better than the flaming POS short-star 3.5 engine with it's typical CR*P GM head/bolt design problems.
The 2001 has an AIR system.
You also don't have the correct ABS for a 2001 ECM. Yes, they ARE MARRIED!
And, so many other problems.
The ECM/BCM must talk to each other. They both control EVERYTHING!!!!!!!!!
As I said, *anyone* that asks if they can go an engine swap, should not even think of it.
Go get a pre '78 GM/Ford car. Swap all you want.
Old April 13th, 2019
Red face
well im stubborn i changed comlete cradle exhaaust dash wiring steering column heater major project runs fine everything works as it should except radio speakers still figuring that out wiring was not plug and play took me 70 -80 hours not a reccomended idea wont do that again
Old April 20th, 2019
sideking sideking is offline
sideking is on a distinguished road
Doesn't make sense
The 3800 was manufactured from 1962 until 2008, the LX5 from 1999 to 2002. Parts are disappearing for the Oldsmobile LX5. Parts for the Buick 3800 will be around for another 20 years at least. The LX5 was discontinued because its gain in horsepower was minimal and it was costly to produce.
The 3800 is a relatively simple little guy to swap out. Perhaps the LX5 came into your possession for little or no expense. However, long-term the 3800 is the better engine to put in one's vehicle.
Update...Sorry. Didn't read your original post carefully. Thought you were doing an engine swap. Glad to hear your transmission went in okay.
