Go Back   Oldsmobile Forums > Older Requested Oldsmobile Models > Oldsmobile Achieva
Oldsmobile Achieva Forum specifically intended for Oldsmobile Achieva based discussions
Oldsmobile Forum: Milky Oil
Old December 30th, 2012
durec durec is offline
durec is on a distinguished road
Milky Oil
Daughter has 1 92 achieva s. She checked the oil today and saw what she referred to as a milky texture to it....my first thought was a leaking head gasket or cracked head. There hasn't been any loss of anitfreeze or any white exhaust. Does anyone have any thoughts as to what else may cause this other than head problems?
Thanks
RalphP2 RalphP2 is offline
RalphP2 is on a distinguished road
Excessive condensation due to a lot of humidity on cold days.
An opening into the oil system that had water in it (say from splashing up into the oil fill cap).
Otherwise, you have a coolant/oil leak.
Safe bet it's not into a pressure galley, but into the return paths, if you don't have oil in the coolant.
RwP
Old December 31st, 2012
C&C C&C is offline
This can occur if the vehicle is used for short trips (not allowing the engine to get up to temperature, which burns off the condensation of startup). This is more likely to happen in colder climates (in the Winter) when, say, people use their car to go to work (short distances), turn off, go back home, repeat.
