Go Back   Oldsmobile Forums > Older Requested Oldsmobile Models > Oldsmobile Eighty-Eight (88) > Oldsmobile 88 RWD
Oldsmobile 88 RWD Forum specifically intended for Oldsmobile Eighty-Eight (88) rear wheel drive based discussions.
Oldsmobile Forum: Window washer mist lever
Old March 4th, 2016
Stephen0523 Stephen0523 is offline
Stephen0523 is on a distinguished road
Hello all this is my first post to this forum.
I inherited a 1984 Delta 88 from my uncles last fall.
The mist lever that activates window washer is broken. The plastic lever just spins around on the turn signal arm.
Does anyone have a good fix for this and instructions?
Thanks in advance!
Stephen
Old March 4th, 2016
1970cs 1970cs is offline
1970cs is on a distinguished road
Look like a nice car and the price was nice also. You have to replace the multi function lever as a whole, the aftermarket will work but will not have the chrome part.
http://www.rockauto.com/en/moreinfo....214974&jsn=448
Pat
Old March 4th, 2016
Thanks 1970, would you know if it is difficult to replace?
Old March 5th, 2016
I am not sure but if you use you tube and there are vidoes of other GM vehicles of that era the should be close enough to give you the help you need.
Pat
Old March 5th, 2016
D. Yaros D. Yaros is offline
D. Yaros is on a distinguished road
Hard to tell from photos, but there may be problems other than the multifunction switch itself. I say this as the photo appears to show a cracked/glued housing and cover.
Before I threw $61.79 + S&H at it, I would want to know that money is not being wasted.
Old March 5th, 2016
Thanks, I believe it would work when the glue was working. I am thinking of how to apply battery directly to the pump also to be sure the pump is still working.
Old March 5th, 2016
https://www.youtube.com/results?q=tu...cement+1994+GM
