Go Back   Oldsmobile Forums > Oldsmobile Etcetera > Oldsmobile Infotainment and Security Systems
Oldsmobile Infotainment and Security Systems Forum specifically intended for Oldsmobile infotainment and security system based discussions.
Oldsmobile Forum: power antenna
Old June 12th, 2009
miguel2112 miguel2112 is offline
miguel2112 is on a distinguished road
power antenna
I just installed a replacement power antenna I got out of an aurora from the local bone yard and it works backwards. Goes up when radio is turned off and goes down when radio is turned on. The wiring and all other components appear the same,any ideas?
Old July 4th, 2009
OK I'll figure it out myself as usual.
Old July 9th, 2009
chemicall chemicall is offline
chemicall is on a distinguished road
Take the plug that feeds the antenna's power, it's 3 wires correct? 1 is ground, 1 is power up, 1 is power down, have someone turn your radio on and off and test with a volt meter to find your 2 power wires, then reverse these 2 wires with each other. now it should go up when you want and down when you want
