Oldsmobile Forum: 95 elite couple of issues
Old July 6th, 2018
surupsamich surupsamich is offline
surupsamich is on a distinguished road
I have a 95 elite with the digital climate control. Problem is it won't turn off. Everything else works as it should just won't turn off. Also how do you know if the temp control on the passenger side is working? It doesn't seem to change the settings on the display. Just got it about 2 weeks ago, going through all the problems and making my parts list.
Old July 9th, 2018
NINETY EIGHT REGENCY's Avatar
Administrator
ADMINISTRATOR
Replace the climate control. Be careful as the plug/socket in the back of the unit in the back change during the production run. Find out what your plug/socket looks like in the back and match it up with photos on Ebay to make sure you do not get one with a different socket/plug than your car. I learned that the hard way. There are plenty of them on Ebay. Watch the prices. Do not always go for the cheap part. The part can be found on Ninety Eight and Eighty Eight, LSS and Regency. I have a 1995 Oldsmobile 98. If you have digital gauges( instrumentation) like me, you will need to get the one with the four buttons on it and two knobs. Those four buttons control the information center. Get the GM part number off the back of the part. I hope this helps..
__________________
RANSOM ELI OLDS REINCARNATED
Old November 22nd, 2018
thank you, its working now, but i think i will need a spare
Old June 15th, 2019
hawgfan hawgfan is offline
hawgfan is on a distinguished road
I have a similar problem with my 1995 Regency Elite. I have the digital dash and climate control. The AC/Heat control in the dash does not light up. The system does not respond to any of the controls. AC blows out of the defroster outlets only.
I have searched CarPart.com and found 6 different units, some with orange LEDs and some with yellow & green LEDs. I can't tell which one I need because nothing lights on mine. Also, probably when my car was detailed at one time someone used a strong cleaner on the door jambs and wiped off all the lettering on the two labels including the one that has the RPO codes. That leaves me like a blind man in the dark trying to find a control that will work on my car.
Old June 15th, 2019
Should have mentioned Car-Part.com, not Carpart,com
Old June 19th, 2019
Administrator
ADMINISTRATOR
the display screen lights up in yellow and green. You pull the climate control out of the instrumentation, the part number is on the back.
__________________
Old July 27th, 2019
The model number on mine is 16206843. My LED's are amber. I have the Driver Information Center and digital dash. I found my option codes on a label on the spare tire cover.
I drove 100 miles from my home in Mena, AR to Russellville, AR where there was supposed to be one with my option codes and amber LEDs. The one they had did not have the buttons for the Driver Info Center so they had advertised the wrong option codes. I was going to Minneapolis and drove about 100 miles out of the way to Lake Crystal, MN They claimed to have one with my option codes, but the one that they had was manual control (3 dials). Again, wrong option codes.
I plan to take the circuit board out of mine and re-solder all the joints. Can't hurt anything since it doesn't work anyway.
Old July 29th, 2019
Administrator
ADMINISTRATOR
I went and looked in my service manual, it was in there too. It was called instrumentation cluster U2A
Proof it was offered on 1994 and 1995 Eighty Eight and Ninety Eight 1994-1996
https://www.gmpartsgiant.com/parts/g...-16198293.html
The climate control has to match. See number:
https://www.ebay.com/itm/94-95-OLDSM...oAAOSwdStc23L~
__________________
  #9
Old July 31st, 2019
Thanks. Gmpartsgiant gives me error code 404. The climate control seems to be the right one but is used and is priced at $330.88, a bit high for a used part with only a 30 day warranty.
I sent my climate control to a guy in Minnesota who thinks he can fix it. He advertises a repair service for Olds Intrigue climate controls for $39.99. He said that if it didn't work he would refund my money. If it does work he offers a lifetime warranty if it fails later. I will post his info if it works.
