Oldsmobile Forum: 1994 Cutlass with 3.1
Old November 24th, 2017
bashmaki bashmaki is offline
bashmaki is on a distinguished road
Just wondering what the optimum running temp is for this car. My son has one of these and the gauge says around 220. He claims it has always run this warm.
I just recently put a radiator in it and I was a little concerned about the operating temp. May be the thermo. is stuck, huh?
Gus
Old November 28th, 2017
Walter F Walter F is offline
Walter F is on a distinguished road
220 is not overheating but is higher than normal operating temp. Mine runs at 205 after working the engine over.
Have you checked the fan motor in the rear (cowl side) of the radiator? This comes on at about 215 and should keep you around 205. The thermostat should have been changed with the radiator. You'll have to drain the system and remove the throttle body.
Thanks Walter,
The fan operates as it should. I did not, however, change the thermostat when I changed the radiator. Us hicks don't think about those type of things. But you're right; that would have been the time to do it.
again, thanks,
Gus
Old December 7th, 2018
Actually, the cooling fans are programmed to run when the temp reaches 230 to 235. The temp gage in the dash will go almost straight up before the fans will kick in. This is normal. Apparently GM wants these engines to run a little on the warm side. I have seen way more of these with "stuck-open" thermostats(meaning no heat) than I have with "stuck-closed" thermostats. If the car has AC, the driver side fan will come on shortly after you turn the AC on.
