Oldsmobile Forum: '94 regency elite won't turn over
Old December 26th, 2011
mikehs mikehs is offline
mikehs is on a distinguished road
'94 regency elite won't crank after installing new battery
Just found this forum...great resource.
Owner of 1994, Olds 98 Regency Elite 3.8
Car was running fine, but battery is 5 years old...so due diligence, put in a new battery. I was very careful with the cables etc., did not over torque the connections...battery is holding a full charge.
Go to turn it over and nothing. information center displays error message "Hot AC disabled, then error code 9.
Appreciate any advice.
Mike
Just did a bit more digging...could this be related to the VATS PASSkey anti-theft module. Please tell me a simple battery swap did not disable my car....
Old December 27th, 2011
pogster pogster is offline
pogster is on a distinguished road
I had a similar thing happen to my car back in June. Took it to the dealer and they traced the problem to a "security circuit through the ignition cylinder open". The fix was to install a bypass resistor in the circuit. That's all that's on the invoice so I can't really tell you much about it.
Hard to say if that would be the same issue you are having or if its related to the HOT AC disabled message. But you would think if the AC were to get hot the compressor would be disabled rather than the whole car.
Old August 30th, 2019
redrum55 redrum55 is offline
redrum55 is on a distinguished road
I know this is an old thread. But i was wondering if you guys found a fix on this "Hot... AC Disabled" message that seems to turn off my olds while driving and wont turn back on till couple days later. Thank in advance.
