Oldsmobile Forum: 1995 Oldsmobile 98 (Hot.......A/C Disabled)
Old August 10th, 2010
fla813 fla813 is offline
fla813 is on a distinguished road
Just bought my 95 oldsmobile 98. Great Car. Everything works, except A/C. Bought some freon and charged system. Air came out of top and bottom, but not the middle vent. Came straight to this forum. Suggestion was a vacuum line, Bingo!(Driver side Firewall). Air came out of all vents. Very happy, then within 48 hours car started shutting off. Got that dreaded "Hot.....A/C Disabled" in the information display. Disconnected vacuum line and have not turned A/C back on. Seems to be running fine. Drove 45 miles to and from no problems. Baffled new olds 98 owner?
P.S.: Fan does not blow very strong. When it was on, it would blow to about the steering wheel(on High), but was weak at that point.
Old August 11th, 2010
1995 oldsmobile 98 owner (Hot........A/C Disabled)
Well, I jumped the gun. With the vacuum line disconnected and not using the A/C, I thought my problem was fixed, WRONG! It cut off again this morning while I was pulling into work. The check Engine light does not come on. I've called around a couple of garages and they said they will test it, but if the check Engine light is not coming on, then it will be difficult to find the problem. I love this car, but i am very frustrated that no one knows what its wrong. This make and model of car has been around awhile, someone should have figured something out by now, you would think.
Old September 10th, 2010
95nientyeight 95nientyeight is offline
95nientyeight is on a distinguished road
Well that is not a good news, since I have the same problem after fixing many parts over last 6 months. That does no good. Only hope mechanic says to do is change the head gasket worth $700. Once the Hot ac disable message appears, I can almost 99% can tell the car becomes a junk.
I don't want to put out off but that is the truth in my case. Better off getting a non GM car.
Old October 10th, 2010
wrd2103 wrd2103 is offline
wrd2103 is on a distinguished road
I had the same message about a week after I got mine in August of this year. I replaced the crank shaft sensor and the problem is fixed. Give that a shot.
Old August 30th, 2019
redrum55 redrum55 is offline
redrum55 is on a distinguished road
I know this is an old thread. But i changed my crank shaft sensor and it seemed to work but after a few days it happened again. Anyone else know what can possibly be the issue. Owned it for over 10 years no check engine light on. I also changed the coolant temp sensor. Most top end gaskets , fuel filter , tune up done less than 1500 miles ago. It has 89k miles 3rd owner.
