Go Back   Oldsmobile Forums > Older Requested Oldsmobile Models > Oldsmobile Cutlass > Oldsmobile Cutlass FWD
Oldsmobile Cutlass FWD Forum specifically intended for Oldsmobile Cutlass front wheel drive based discussions.
Oldsmobile Forum: 3.1 stalls when hot
Old June 5th, 2017
Walter F Walter F is offline
Walter F is on a distinguished road
3.1 stalls when hot
My 1994 Cutlass wagon would start and run fine but stall after about 15 minutes. I'd have to let it cool for 5 minutes to get going again for a short distances before it stalled again.
It turns out that the problem was the connection to the second crankshaft position sensor (there are 2: 1 behind the harmonic balancer and a second in the rear of the block) had frayed on the exhaust manifold and would ground to short when hot. This caused the computer to sense a miscommunication between the cam position sensor and the subject crank sensor causing an ignition shut down. My check engine light (MIL) was disconnected by some previous owner so I don't know if this would result in a blink out code.
This was not an easy fault to diagnose so I hope this post can be of help to some other Olds owner.
cars connected social network cars connected social networking app for ios cars connected social networking app for android
Copyright ©2000 - 2017, vBulletin Solutions Inc.
